Anonymous
Not applicable
sata validatation on ML605
I am doing FPGA validation on ML605 with virtex 6 gtx transceiver.
After OOB and speed negotiations, when actual transfers started, we are seeing disparity and decode errors on rx lines.
But received data's CRC is corrected.
Are we getting these errors because of RX Equlazation settings?
if so kindly post me the RX and TX setting for virtex 6 gtx phy.
Thanking you
Community Manager
Community Manager
Which version of GT core are you using?
If it is v1.6 or earlier, please refer to http://www.xilinx.com/support/answers/35653.htm
In general, data errors attributes to poor channel. I would recommend you to first test the quality of your channel using IBERT and make sure that you achieve a good BER.
Are you targeting SATA gen 1/2/3?
Please note that Gen3 in not officially supported i.e. we don't have the characterized attributes/parameter values of GTX for SATA gen3 protocol.
Krishna
when you find disparity errors and notintable errors, can you try asserting GTRXRESET and check?
