Observer lino89
virtex 6 iodelay1
i need iodelay1 block in my design but from simulation my delay between ny datain and dataout are not as expected.
its showing without the delay of my cnt value.
pls help me to resolve this problem.
Re: virtex 6 iodelay1
Are you running behavioral simulation?
If yes, try running post route simulation (timing simulation).
Observer lino89
i am not familiar with that simulation
how to do that.
Steps to follow:
1. Implement the design.
2. double click on post place and route simulation model (Snapshot below)
3. Then switch to simulation (snapshot below)
4. Then double click on "simulate Post-Place & route simulation"
Observer lino89
IT IS ASKING FOR IDELAYCTRL IS THIS CONNECTION RIGHT
Observer lino89
done it still has the same problem
Community Manager
Community Manager
Can you share the testcase to reproduce the issue?
Observer lino89
the delay is not based on tap value
i need var_loadable mode of iodelay
from the datasheet they have given that the delay is based on the cntvalue we give to the iodelay1 block
i also didn't understand to use idelayctrl
I think you should connect the invert of the RDY output from IDELAYCTRL to RST input of IODELAYE1. This will ensure to make IODELAY operate only after IDELAYCTRL is ready.
Please note that idelayctrl must be reset if RDY output goes LOW because of the absence of REFCLK at later point.
