Anonymous
Not applicable
virtex6 speed grade
My name is P Dasarath.
I have working on a project with following fpga board configuration.
VIRTEX6 XC6VLX240T FF1156 with Speed grade  -1 ( ML605 evalution board).
for Gen1 and Gen2 of SATA used the above configuration. It s working fine.
For Gen3 the above board is not supporting, so i moved to VIRTEX6 XC6VLX240T FF1156 with Speed grade  -3.
Every thing is same except the SPEED GRADE.
My question is Can i use the same pin locations for both configuration ( speed grade -1 and -3).
I mean  does the both boards ( speed grade -1 and -3 ) have the same pin structure ?
Kindly respond as soon as possible.
Thanking you,
P Dasarath.
p,
Did you syntehsize, place and route the design with new constraints to match the need for the higher speed?
Austin Lesea
Principal Engineer
Xilinx San Jose
pin locations does not depend on speed grade.
Speed Grade (-1, -2, -3 ,...) influences a variety of "Timing parameters" in the FPGAs. In modern Xilinx FPGA products, the higher numbers are faster. When you switch to a faster speed grade, it will affect ONLY the timing parameters and it is independent of pin locations...
