where is pin definition of ML505 rs232 port ?
I am newbie to FPGA.  I am using a serial port to pass data from FPGA to PC through virtex 5 ML505.  From "ML505/506/507 evaluation platform user guide" I know that there is a rs232 port available, and COM1 is the pins for it.
But what is the pin assignment to this port, so I can finish the pin assignment in ISE?
thank you.
This information is included in the ML505 User Guide and the schematics for the board. These are available at
http://www.xilinx.com/ml505
Thanks,Vijay
you can find pin location in ML505 schematics as well
www.xilinx.com/support/documentation/.../ml50x_schematics.pdf
Thanks and Regards
Balkrishan
For ML505, the RS232 pin assignment can be as shown below:
# Virtex 5 ML505 Evaluation Platform
Net fpga_0_RS232_Uart_1_RX_pin LOC = AG15 | IOSTANDARD=LVCMOS33;
Net fpga_0_RS232_Uart_1_TX_pin LOC = AG20 | IOSTANDARD=LVCMOS33;
Net fpga_0_RS232_Uart_2_RX_pin LOC=G10 | IOSTANDARD = LVCMOS33;
Net fpga_0_RS232_Uart_2_TX_pin LOC=F10 | IOSTANDARD = LVCMOS33;
