xst:2636
at synthesize i got an error like
 ERROR:Xst:2636 - "memory.v" line 54: Loop has iterated 10000 times. Use "set -loop_iteration_limit XX" to iterAnalyzing top module <memory>.
ERROR:Xst:2636 - "memory.v" line 54: Loop has iterated 10000 times. Use "set -loop_iteration_limit XX" to iterate more so what to do.
where i can set loop iteration.
Instructor
Instructor
Re: xst:2636
Before you decide to set the loop iteration limit, did you check your code to
see if it makes sense that a loop should iterate more than 10000 times?
If you're not sure, maybe you could post the offending lines of code.  Usually
large number of loop iterations indicate that you've created an infinite loop,
either by forgetting to increment th loop variable, or using an end condition
that cannot be reached, for example comparing the loop variable to
a number too large to fit in its size.
Gabor
-- Gabor
Historian
Historian
Re: xst:2636
Check your code. You have a bad combinatorial loop somewhere. Fix it.
