Visitor 44026
What does GTP/GTX stand for?
Dear Xilinx people,
this may look like a silly question but what does GTP and GTX mean? I couldn't find a definition for that anywhere.... I suppose GT is for "Gigabit Transceiver" evolved from the MGT, but does "P" & "X" have a special meaning? I refer to the transceiver in my diploma thesis and want to give a short definition what the names stand for.
Hope someone can clear this up...
Chris
Re: What does GTP/GTX stand for?
Chris,
Officially - they have no meaning... They are just names for primitives.
Each of our transceivers has so far had a unique library name:
GT - Virtex-II Pro
GT10 - Virtex-II Pro X
GT11 - Virtex-4 FX
GTP - Virtex-5 LXT/SXT
GTX - Virtex-5 FXT/TXT
I have heard several different internal comments on the origin of the GTP/GTX naming, but nothing that is official... You should just call them what they are... ;)
Chris,
GT - Virtex-II Pro
GT11 - Virtex-4 FX
Visitor 44026
Hm, okay. I never had guessed that.
I will just describe what they do... ;-)
Chris
Good luck.
The GTP and GTX transceivers are architecturally very similar.
The details are outlined in the respective User Guides and datasheets.
But the high-level differences are:
-GTX supports higher line rates (and different REFCLK rates)
-GTX adds the TX and RX gearboxes (64/66, 64/67)
-GTX adds the decision feedback equalizer between the RX EQ and RX CDR.
-GTX dissipates more power
-slight changes to board design (MGTAVCCPLL voltage and MGTRREF resistor value)
The Architecture Wizard and Chipscope Serial I/O Toolkit (IBERT) are good resources to be aware of.
The GTP/GTX are very different from the GT11 - I guess it could be argured they are next closest to the GT, but there are still a fair amount of differences there.
bt
Newbie mydavisl
GTP stands for Gigabit Transceiver with Low Power.
Visitor pbeerdeke
Xilinx ug190 defines the GT prefix as "Gunning Transceiver" on pg248
http://www.xilinx.com/support/documentation/user_guides/ug190.pdf
UG190 is the Virtex-5 FPGA User Guide and page 248 is referring to two SelectIO standards GTL and GTLP that are used primarily in telecom backplane applications.  In this context, GT does means Gunning Transceiver, but it has nothing to do with the original question regarding the high speed serial transceivers GTP and GTX blocks.
That question was answered 3 years ago.
Teacher rcingham
"That question was answered 3 years ago."
It would make sense to lock these old threads...
