Visitor rishith27
virtex II pro interfacing
Hello. I'm currently working on digital audio processing. I am using Virtex II pro board for this purpose. I am facing troubles on how to use the board and which ports to use to give inputs. Please help me out with a tutorial on how to use the board for this purpose.
Scholar drjohnsmith
Re: virtex II pro interfacing
There are many boards that this could be, were going to need some more info as to what the board is.
Were also going to have to know a lot more as to your experience so we can tailor our responses.
Visitor rishith27
I know basic verilog and i am familiar with xilinx ise software. I have worked with a custom spartan3 , XC3S400 fpga board.
The project that we're  working on is 'Synthesis of digital audio effects'.  We intend to create different audio effects like echo, chorus, flange, reverberation with a given audio file. We want to input an audio(.wav) file and get these sound effects as output from the board.
Currently we are using virtex 2 pro board whose pictures are uploaded . We are unfamiliar with this fpga board. We are not able to find any tutorials for this purpose.  Please help us out in this regard.
Scholar drjohnsmith
that looks like a very old board,
do you have the board number / type
BTW: If ts just to do audio effects, try a teensy processor,
https://www.pjrc.com/teensy/td_libs_Audio.html
Visitor rishith27
This is the board that we have on hand.
Its number is XC2VP30.
Scholar drjohnsmith
thats the chip your pointing at,
the green boards number is what you need to search for.
You have two boards there, small one from digilent, the big one from xilinx dev labs, which is effectively a digilent as well I think.
would this help
https://store.digilentinc.com/virtex-ii-pro-fpga-development-system-limited-time/
Visitor rishith27
Wil check out both the links... Thanks
