jerald93
ALVEO-U200 helloworld_ocl "system" run failure, Result mismatch
i have been trying out examples in SDAccel with alveo-u200 card on dell R740 server running ubuntu-16.04. I am able to compile and run "helloworl_ocl" example found at https://github.com/Xilinx/SDAccel_Examples/tree/master/getting_started/hello_world in sw emulation and hw emulation modes with correct output, but when i compile and run same in system or in HW mode i am getting failure with following log
Found Platform
Platform Name: Xilinx
Found Device=xilinx_u200_xdma_201830_1
INFO: Reading ../vector_addition.xclbin
Loading: '../vector_addition.xclbin'
Result =
Error: Result mismatch:
i = 0 CPU result = 42 Device result = 0
TEST FAILED
I am using "Xilinx SDx v2018.3 (64-bit) SW Build 2405991 on Thu Dec 6 23:37:15 MST 2018" for development, also tried building same with command line options and produsing similar issue.
following are the DSA details
	Card BDF:		0000:af:00.0
	Card type:		u200
	Flash type:		SPI
	DSA running on FPGA:
		xilinx_u200_xdma_201830_1,[TS=0x000000005bece8e1],[BMC=3.1]
	DSA package installed in system:
There is no modification in the example. looking forward to your replies
jerald93
Thanks for the support. Issue was due to DMA failure.While running "XButil validate" command same error came.This may due to ubuntu grub configuration change for enabling IOMMU(This was done for some other project).When that change is reverted DMA failure resolved and application run in HW mode successfully without any problems.I dont understand why Intel IOMMU enble configuration affect DMA and shell installtion
graces
Did you run the Make command for the emulations and hw deployment?
jerald93
Yes for command line building. I used IDE for last several builds with just pressing run option on the IDE with "Active build configuration" choosed as system"
jerald93
This is the status of build
Test                     Command line(MAKE)         SDx(IDE)
SW_emu                 success                               success
HW_emu                 success                              success
HW                           Result mismatch                result mismatch
And in case of make there is build error due to invalid folder name for vivado(attached log file - 01_make_build_error.txt ).i resolved that by modifying " . " in folder name by " _ ". for IDE there is no build error.
attaching build log(02_build_log.txt) and run log (03_run_error.txt) showing error.
I also tried to run "SDAccel_Examples/vision/edge_detection", both Hw emulation and sw emulation was success but Hw run failed.
graces
I was unable to reproduce the failure, neither did I received any build error in Make flow.
make all DEVICES=xilinx_u200_xdma_201830_1
It looks you don't have the same naming .xclbin as defined in the Makefile.
BINARY_CONTAINERS += $(XCLBIN)/vector_addition.$(TARGET).$(DSA).xclbin
jerald93
Thank you for trying out the example.
I tried same example in nimbix cloud instance and got build error and i modified make file as i mentioned in previous reply. Test was successfull and got the correct result.
But in my local dell server setup it is still producing error and result mismatch. I am unable to understand what is missing in my setup
jerald93
The build error was due to DEVICE variable problem.i have been specifying it like below
/opt/xilinx/platforms/xilinx_u200_xdma_201830_1/xilinx_u200_xdma_201830_1.xpfm
when i changed that to only "xilinx_u200_xdma_201830_1" build was successful without any make file modification, but still Result mismath error is coming on Dell server setup
jerald93
