BiscuitsColonel
About the data_compression library of Vitis_Library
The vitis_library seemed to support zstd, but only decommpress supported it.
Do you have any plans to support commpress in the future?
Or is there a way to implement it?
Thank you!
heeran
Hi @BiscuitsColonel ,
Yes, zstd compression is already in our plan and we will be releasing first version (single core solution) soon in Vitis Library.
If possible, could you please share your end application and target performance what you are expecting for zstd compress/decompression. You can also reach out to me directly on heeran@xilinx.com for any further discussion on zstd requirements and usecase.
-Heera
BiscuitsColonel
It was good.
I would like to use it to improve the compression / decompression function of zfs or, read / write function of table in DB.
I hope I can use the binary file without separating the compression / decompression function.
This is due to the time it takes to reprogram to the FPGA.
I'm new to FPGAs, so I might be saying something wrong.
