OparinVD
Access buffers in U50 with XRT API
I use Vitis 2020.1 and the corresponding XRT. I want to access buffers in U50 with native XRT APIs such as xrtBOAllocUserPtr, xrtBOSync, and so on. But I can't see "xrt_bo.h" in XRT directory, not in "experimental/xrt_bo.h" nor "xrt/xrt_bo.h". Does it mean, the current platform doesn't support buffer transfers (it would be strange)?
I checked XRT for 2020.2.1, "xrt_bo.h" presents in "experimental/" directory. Can I use it with the old platform or do I need to completely migrate to the 2020.2.1 version?
minx
Hello
    From 2020.2 ,XRT start to support the native api, So you have to upgrade the xrt version.
   and you'd better use the U50-gen3x16-201920_3_1 shell if you use 2020.2 xrt
Min
minx
Hello
Min
