benedetto73
Alveo U280: maximum number of ports per binary container
Target system is my Alveo U280  (C++ Vitis on Linux Ubuntu).
I am building a system with the intention of fully using:
- the entire HBM memory space.
- ALL 32 HBM memory ports.
- the 2 DDR ports.
From the error below that I get during EMU-HW build, I assume that there's a limit of 32 ports per binary container.
Q1:  Is that correct?  Do we have a limit of 32 ports per binary container?  I can't find it anywhere on the references.
Q2: Although tempted to ask "why?", my question is if it's possible to increase this limit, somehow. It really is a design killer in my case.
INFO: [hbm_memory_subsystem 1-1] Mapping resources for kernel master /kSortL1_1/m_axi_hbm0 on HMSS port 1.
INFO: [hbm_memory_subsystem 1-1] Mapping resources for kernel master /kSortL1_1/m_axi_hbm1 on HMSS port 2.
INFO: [hbm_memory_subsystem 1-1] Mapping resources for kernel master /kSortL1_1/m_axi_hbm2 on HMSS port 3.
INFO: [hbm_memory_subsystem 1-1] Mapping resources for kernel master /kSortL1_1/m_axi_hbm3 on HMSS port 4.
INFO: [hbm_memory_subsystem 1-1] Mapping resources for kernel master /kSortL1_1/m_axi_hbm4 on HMSS port 5.
INFO: [hbm_memory_subsystem 1-1] Mapping resources for kernel master /kSortL1_1/m_axi_hbm5 on HMSS port 6.
INFO: [hbm_memory_subsystem 1-1] Mapping resources for kernel master /kSortL1_1/m_axi_hbm6 on HMSS port 7.
INFO: [hbm_memory_subsystem 1-1] Mapping resources for kernel master /kSortL1_1/m_axi_hbm7 on HMSS port 8.
INFO: [hbm_memory_subsystem 1-1] Mapping resources for kernel master /kSortL1_1/m_axi_ddr0 on HMSS port 9.
INFO: [hbm_memory_subsystem 1-1] Mapping resources for kernel master /kSortL1_2/m_axi_hbm0 on HMSS port 10.
INFO: [hbm_memory_subsystem 1-1] Mapping resources for kernel master /kSortL1_2/m_axi_hbm1 on HMSS port 11.
INFO: [hbm_memory_subsystem 1-1] Mapping resources for kernel master /kSortL1_2/m_axi_hbm2 on HMSS port 12.
INFO: [hbm_memory_subsystem 1-1] Mapping resources for kernel master /kSortL1_2/m_axi_hbm3 on HMSS port 13.
INFO: [hbm_memory_subsystem 1-1] Mapping resources for kernel master /kSortL1_2/m_axi_hbm4 on HMSS port 14.
INFO: [hbm_memory_subsystem 1-1] Mapping resources for kernel master /kSortL1_2/m_axi_hbm5 on HMSS port 15.
INFO: [hbm_memory_subsystem 1-1] Mapping resources for kernel master /kSortL1_2/m_axi_hbm6 on HMSS port 16.
INFO: [hbm_memory_subsystem 1-1] Mapping resources for kernel master /kSortL1_2/m_axi_hbm7 on HMSS port 17.
INFO: [hbm_memory_subsystem 1-1] Mapping resources for kernel master /kSortL1_2/m_axi_ddr0 on HMSS port 18.
INFO: [hbm_memory_subsystem 1-1] Mapping resources for kernel master /kSortL1_3/m_axi_hbm0 on HMSS port 19.
INFO: [hbm_memory_subsystem 1-1] Mapping resources for kernel master /kSortL1_3/m_axi_hbm1 on HMSS port 20.
INFO: [hbm_memory_subsystem 1-1] Mapping resources for kernel master /kSortL1_3/m_axi_hbm2 on HMSS port 21.
INFO: [hbm_memory_subsystem 1-1] Mapping resources for kernel master /kSortL1_3/m_axi_hbm3 on HMSS port 22.
INFO: [hbm_memory_subsystem 1-1] Mapping resources for kernel master /kSortL1_3/m_axi_hbm4 on HMSS port 23.
INFO: [hbm_memory_subsystem 1-1] Mapping resources for kernel master /kSortL1_3/m_axi_hbm5 on HMSS port 24.
INFO: [hbm_memory_subsystem 1-1] Mapping resources for kernel master /kSortL1_3/m_axi_hbm6 on HMSS port 25.
INFO: [hbm_memory_subsystem 1-1] Mapping resources for kernel master /kSortL1_3/m_axi_hbm7 on HMSS port 26.
INFO: [hbm_memory_subsystem 1-1] Mapping resources for kernel master /kSortL1_3/m_axi_ddr0 on HMSS port 27.
INFO: [hbm_memory_subsystem 1-1] Mapping resources for kernel master /kSortL1_4/m_axi_hbm0 on HMSS port 28.
INFO: [hbm_memory_subsystem 1-1] Mapping resources for kernel master /kSortL1_4/m_axi_hbm1 on HMSS port 29.
INFO: [hbm_memory_subsystem 1-1] Mapping resources for kernel master /kSortL1_4/m_axi_hbm2 on HMSS port 30.
INFO: [hbm_memory_subsystem 1-1] Mapping resources for kernel master /kSortL1_4/m_axi_hbm3 on HMSS port 31.
INFO: [hbm_memory_subsystem 1-1] Mapping resources for kernel master /kSortL1_4/m_axi_hbm4 on HMSS port 32.
ERROR: [hbm_memory_subsystem 1-1] You have run out of port connections on /hmss_0. All 33 connections are used (0 ports prohibited)...
Tags (3)
nirdhish
Hi benedetto73,
It looks like the tool is trying to connect the 2 DDR ports to HBM as well. Have you set the corresponding port connections to DDR ports using --connectivity.sp?
benedetto73
I connected everything properly using the GUI.
The real discovery here (please Xilinx people come in to confirm) is that the provided Alveo U280 shell supports a maximum of 32 total ports for all CUs.
