BradleyB9
Approximate how long a hw_emu run will take?
Hello! I am trying to run hardware emulation on a kernel. The kernel compiles for both hw_emu and sw_emu. For sw_emu the run is almost instant.
I understand that hw_emu takes a lot longer but it's been going for a few hours now and is only at an emulation time of 25ms. I was wondering if there was a way to get an approximate of how long the kernel will take? (Just a smaller range, right now I have no sense of how long the kernel will take).
Please let me know if you have any ideas!
ViratAgarwal
Hi @BradleyB9,
Hw_emu takes much more time when compared to hw or sw_emu. While for the same data set (For ex - 1GB) the board run might take a few seconds, the hw_emu can take hours (I have even seen it running for 12 hours). That's why most of our examples have a very small data size for hw_emu and a large one for hw. You may refer to the following example for the same -
https://github.com/Xilinx/Vitis_Accel_Examples/blob/master/host/streaming_k2k_mm/src/host.cpp#L60https://github.com/Xilinx/Vitis_Accel_Examples/tree/master/host/hbm_bandwidth
BradleyB9
So is there any way to actually get a sense of how the emulation will take? Fo my case, I cannot decrease the data size.
EDIT: also, I am only transferring 8.5 kB of data
ViratAgarwal
Hi @BradleyB9 ,
8.5 KB is a fairly small size . It shouldn't take more than an hour to work(Although it totally depends on the case). Are you sure the example hasn't gone into a hang state? Can you please share your hw_emu running logs. Also, can you please try running the example for hw as well?
BradleyB9
Which logs should I attach. The only ones I can see are the print outs of the emulation time.
I am guessing that my program went into a hang state. Is there any way to debug during hardware emulation with breaks/print statements etc? Right now, running and stopping at different points is very costly.
ViratAgarwal
Hi @BradleyB9,
You may share the vitis_hls.log of the run. The print outs of the emulation time is actually the feature added to notify the user about the progress of the hw_emu. It tells you how much data transfer has taken place in every 5 minutes (If it is consistently coming for you as 0KB it means its definitely a hang).
The issue can be because of a deadlock occurring somewhere in your code. You may analyze the hw_emu waveform to monitor the various data transfers involved. The same can be done by adding the following the xrt.ini file -
[Emulation]
launch_waveform=GUI
