xil_tour
Best way to move a SDx project to another computer
I would like to migrate a SDx project to another computer, with another account, another file tree etc.
What's the best way to do it ?
So far, my attempt to create and move an archive have failed as it seems that paths are hardcoded into the project.sdx file.
So I currently recreate a new project, copy the sources, set again the build parameters etc.
yashp
https://www.xilinx.com/html_docs/xilinx2018_3/sdaccel_doc/vow1532067628021.html
Refer SDx project export and import. I tried this locally at my end with one of the example project and it worked for me.
Yash
yashp
Yash
xil_tour
Ok, thanks for your time.
