11-12-2018 01:29 AM
I am trying to build an FPGA binary from an OpenCL kernel ("Krnl_GA") with SDx-2017.4, but the process fails: "DEBUG_IP_LAYOUT segment (7208) exceed the maximum size of 4096".
Here are the linking options used:
... INFO: [XOCC 60-586] Created xclbin/Krnl_GA.hw.xilinx_aws-vu9p-f1-04261818_dynamic_5_0.xo INFO: [XOCC 60-791] Total elapsed time: 0h 29m 58s mkdir -p xclbin /opt/cad/xilinx/sdx/SDx/2017.4/bin/xocc -l
--xp "param:compiler.version=31"
--xp "param:compiler.preserveHlsOutput=1"
--xp "param:compiler.generateExtraRunData=true"
-s -g -I./ -I../ -I./device
-o xclbin/Krnl_GA.hw.xilinx_aws-vu9p-f1-04261818_dynamic_5_0.xclbin
-t hw
--platform /home/wimi/lvs/DSA_SDACCEL_AWS_VU9P/xilinx_aws-vu9p-f1-04261818_dynamic_5_0/xilinx_aws-vu9p-f1-04261818_dynamic_5_0.xpfm
xclbin/Krnl_GA.hw.xilinx_aws-vu9p-f1-04261818_dynamic_5_0.xo ...
After a while, it outputs:
... [02:36:40] Finished 5th of 6 tasks (FPGA routing). Elapsed time: 00h 59m 21s [02:36:40] Starting bitstream generation.. INFO: [VPL 60-841] Created output file: ./address_map.xml INFO: [VPL 60-841] Created output file: ./_new_clk_freq INFO: [VPL 60-841] Created output file: ./routed.dcp INFO: [XOCC 60-991] clock name 'clk_extra_b0' (clock ID '0') is being mapped to clock name 'DATA_CLK' in the xclbin INFO: [XOCC 60-991] clock name 'clk_extra_c0' (clock ID '1') is being mapped to clock name 'KERNEL_CLK' in the xclbin INFO: [XOCC 60-991] clock name 'clk_main_a0' (clock ID '') is being mapped to clock name 'clk_main_a0' in the xclbin setting depth of 16 for xcl_pipe_chan_GA2IGL_GG_active setting depth of 16 for xcl_pipe_chan_GA2IGL_IC_active ... INFO: [CF2SW 83-2205] Adding clock connections... INFO: [CF2SW 83-2206] Adding reset connections... ERROR: [XOCC 60-399] xclbincat failed, please see log file for detail: '/home/wimi/lvs/ocladock-fpga-sdx17_4/ocladock-fpga/ofdock_taskpar_xl/_xocc_link_Krnl_GA.hw.xilinx_aws-vu9p-f1-04261818_dynamic_5_0_Krnl_GA.hw.xilinx_aws-vu9p-f1-04261818_dynamic_5_0.dir/impl/build/Krnl_GA.hw.xilinx_aws-vu9p-f1-04261818_dynamic_5_0_xclbincat.log' ERROR: [XOCC 60-626] Kernel link failed to complete ERROR: [XOCC 60-703] Failed to finish linking make[1]: *** [xclbin/Krnl_GA.hw.xilinx_aws-vu9p-f1-04261818_dynamic_5_0.xclbin] Error 1 make[1]: Leaving directory `/home/wimi/lvs/ocladock-fpga-sdx17_4/ocladock-fpga/ofdock_taskpar_xl' make: *** [hw] Error 2
The contents of the "Krnl_GA.hw.xilinx_aws-vu9p-f1-04261818_dynamic_5_0_xclbincat.log" log file are:
ERROR: The buffer size for the DEBUG_IP_LAYOUT segment (7208) exceed the maximum size of 4096.
I could not find any information related. What could be causing this?
Any help would be greatly appreciated.
Leo
11-12-2018 07:51 PM
Hi, @leonardo.solis ,
In SDx 2018.2, the maximum size of DEBUG_IP_LAYOUT increases from 4K to 64K, it may help to resolve the issue.
11-12-2018 08:42 AM
Could you test the same design in SDx 2018.2?
11-12-2018 08:54 AM
Hi @hongh,
I will try v2018.2.
Also I have just notice that as a linking flag for "hw" mode I added "-g". However I read that in ug1023 that this may be used only for sw-emu or hw-emu.
Could this be the reason? I have restarted the build process and waiting ...
11-12-2018 10:11 AM
11-12-2018 07:51 PM
11-13-2018 07:56 AM
Hi @hongh,
I realized that in my main project folder there was file that had the "debug_ip" configuration. It seems it was automatically created when I enabled the "-lapc" (AXI protocol checkers) and "spm" (SDx performance monitors) flags a couple of weeks.
Although for this time I disabled such options in my Makefile, the tool was still throwing the DEBUG_IP_LAYOUT error. So, deleting such file solved it.
Anyway, I obtained the same error message in my previous experiment (having explicitly enabled "lapc" + "spm"). In that case, it was more obvious to get such error because I enabled monitoring on several AXI ports. For another experiment like that I will consider SDx v2018.2
Many thanks!
Leo
