Build shared library for a function in order to call it on FPGA
Hi all! I have a code in Rust, from which I am calling an external C function. I want this function to be executed on FPGA. I have right hardware for me to do this. What is the best way to do this? Build a library for this function in SDAccel? Is it documented somewhere how to do this? In SDAccel I should probably write also a host code, that calls this function or this is not necessary for shared library?
If you intend to make external C function to be executed on FPGA, you can try to compile it in a kernel. For the host code, you just need to call the kernel.
