candycrush
Building project make makefile reset
I want to use multiple ddr banks for rtl kernel.
I did package rtl kernel for build, but when I build using vitis IDE, it resets makefile so revised makefile and cfg files can't be used.
How can I apply revised makefile for rtl kernel?
Thank u!
hongh
HI, @candycrush ,
The Make file generated by Vitis IDE will be updated automatically when the project is rebuilt.
Please refer to the below discussion and set the memory connection for Kernel in Vitis IDE GUI:
https://forums.xilinx.com/t5/Vitis-Acceleration-SDAccel-SDSoC/How-to-assign-Ports-in-Vitis-to-HBM-Banks/m-p/1152109
candycrush
Thank u for replying!!
I solved by your help.
