freeze
C/C++ and/or RTL Kernel Hierarchy Support
Is there a mechanism to support C/C++ and/or RTL kernel hierarchy (aka encapsulation)?
For example,
                                      ______________________________________
                                     |          RTL (or C /C++) Top-Kernel        |
                                     |     ________________________________     |
                                     |    |    RTL (or C/C++) Sub-Kernel    |    |
                                     |    |________________________________|    |
                                     |______________________________________|
hongh
You can keep your kernel with hierarchy.
But the interfaces of the kernel are all in top level of kernel and the kernel will be compiled as a CU depending on FPGA's architecture. (No PE in FPGA)
HRZ
I am not sure about RTL kernels, but you can have sub-functions in C/C++ kernels and unless you use "#pragma HLS inline" or the compiler automatically inlines the sub-function, the sub-function will appear as a separate level of hierarchy in the resulting RTL code generated by the HLS compiler (Reference: https://www.xilinx.com/html_docs/xilinx2019_1/sdaccel_doc/hls-pragmas-okr1504034364623.html#jka1504034359550). However, note that you cannot call the sub-function from the host side; you can only call the top-level function from the host.
hongh
