pdiffley
Can SDAccel kernels use C++ templates?
I would like to make a kernel that can be used with various datatypes.
brucey
You can use templates but do not use templates as top-level function.  For top-level function, you need to create unique instances.
brucey
brucey
brucey
pdiffley
Thanks!
