lygw
Can ap_int<512> be used during calculation to store a big number which may overflow in type unsigned int ?
I know data type ap_int can be used during reading and writing memory but I want to know if it can also be used during normal calculation in the compute units as a substitute of int or unsigned int. If not, what data type can I use to store a big number which may larger than the maximum of the data type unsigned int ?
bchebrol
Hi @lygw ,
you can use ap_int<datawidth_size> for you design.
Please refer the following design for reference :
https://github.com/Xilinx/Vitis_Accel_Examples/blob/master/cpp_kernels/wide_mem_rw/src/vadd.cpp
Vishnu
bchebrol
Hi @lygw ,
Vishnu
hongh
In default, you can change the bit types to ap_int<N> or ap_uint<N>, where N is a bit-size from 1 to 1024.
Is it enough for you?
lygw
I got it! Thank you for your help!
lygw
It's enough! Thank you for your explanation!
