pmaurice
Can't launch any Emulation-SW on accelerated vitis platform (other config dont even compile...)
Running SW Emulation
INFO : [LAUNCH_EMULATOR] pl_sim_dir option is not provided.
Starting QEMU
- Press <Ctrl-a h> for help
Waiting for QEMU to start. qemu_port 8121
Qemu_pids 28125 28126
qemu-system-aarch64: -chardev socket,path=/tmp/28042/qemu-rport-_pmu@0,server,id=pmu-apu-rp: info: QEMU waiting for connection on: disconnected:unix:/tmp/28042/qemu-rport-_pmu@0,server
QEMU started. qemu_pid=28125.
Waiting for PMU to start. Qemu_pids 28129 28130
qemu-system-aarch64: -chardev socket,id=pl-rp,host=127.0.0.1,port=9626,server: info: QEMU waiting for connection on: disconnected:tcp:127.0.0.1:9626,server
/root/workspace/testacce/export/testacce/sw/testacce/qemu/pmufw.elf: No such file or directory
qemu-system-microblazeel: -device loader,file=/root/workspace/testacce/export/testacce/sw/testacce/qemu/pmufw.elf: Cannot load specified image /root/workspace/testacce/export/testacce/sw/testacce/qemu/pmufw.elf
PMC started. pmc_pid=28129
Starting PL simulation.Generating PLLauncher commandline
running PLL Launcher
[LAUNCH_EMULATOR] INFO: 15:36:05 : PMU/PMC-QEMU exited
qemu-system-aarch64: /pmu@0: Disconnected clk=0 ns
[LAUNCH_EMULATOR] INFO: 15:36:07 : PS-QEMU exited
[LAUNCH_EMULATOR] INFO: 15:36:07 : PMU/PMC-QEMU exited
[LAUNCH_EMULATOR] INFO: 15:36:07 : Trying to kill PLLauncher forcefully because QEMU exited
[LAUNCH_EMULATOR] INFO: 15:36:07 : PLLauncher exited by force
Please refer PS /simulate logs at /root/workspace/truc/Emulation-SW/package for more details.
DONE!
INFO: Emulation ran successfully
pmaurice
how i can share??
stephenm
The QEMU args are delivered in the platform. These are passed to the tools to be able to launch the emulators. Are you using a custom platform/
Can you share it?
pmaurice
do what?
pmaurice
how i can share??
