Cannot find reference-files dir in RTL Kernel Wizard
Hi, I've ZCU104 platform with Vitis 2020.1 on CentOS 7.7.
I want to create a RTL kernel which could be called by host(C++).
Because there is a complete flow which contains the host & RTL kernel in tutorial RTL Kernel Wizard Flow, I followed it to test.
Whereas, I met a bottleneck in the RTL Kernel Wizard Flow next step: Vivado Design Suite - RTL Design
I cannot find "reference-files" directory, and it causes that I cannot do the next step...
I found that the tutorial uses Xilinx u200(Alveo Data Center) as platform. Is it exactly adaptive on ZCU104? Or the directory structure is different?
Any help will be highly appreciated!
You can clone the Tutorial repository from this location:
https://github.com/Xilinx/Vitis-Tutorials
It includes the source files required for the tutorials, including the RTL Kernel tutorial you are following:
https://github.com/Xilinx/Vitis-Tutorials/tree/master/Hardware_Accelerators/Feature_Tutorials/01-rtl_kernel_workflow/reference-files
For the platform issue, the source files are the same, and the build results will be similar though not identical, but it is the build commands that will vary as you need to provide additional details for the embedded processor platforms.
Dear randyh:
Thanks for your reply!
I've cloned the Vitis-Tutorials and studied the reference-files dir.
I found the content inside the "reference-files/src" dir(include sub-dir: IP, testbench &  xml) which is almost the same as "imports" in Linux.
ex. Compare content inside the "reference-files/src/IP" & "imports" dir:
Therefore, I guess MAYBE that "reference-files/src" dir becomes "imports" dir now. Is it right?
Thus, I selected "imports" dir instead of "reference-files/src/IP" dir as IP dir & selected Vadd_A_B_tb.sv.
However, it met error in final step: "Generate RTL Kernel"...
And I put the detail message in the attached file.
Please help me to solve this issue... Thanks a lot!
Dear randyh:
I think I've understood what you said. The "reference-files" isn't created by project automatically. User needs to downloads the directory from git and puts it into your project directory.
After I used the method, I completed all step in Vivado Design Suite - RTL Design .
Thanks for your help!!
