03-26-2020 08:29 AM
Hi Everyone,
First of all, After a quick google, I came know this question has been asked about 3 times and I tried every solution provided in those questions.
I am using vivado and vitis 2019.2. If I try to program my fpga I got this error: Cortex-A53 #0 (target 9) Stopped at 0x0 (Cannot resume. Cannot read 'pc'. Cannot read 'r0'. Instruction transfer timeout).
Log files can be found in attachments.
How can I resolve this issue?
Any help would be appreciated.
With Regards,
Saini
04-01-2020 09:27 AM
Clue 1: The debugger couldn't execute the code from 0x0 (your DDR)
Clue 2: Everything worked when you used another memory
Clue 3: Engineers put more effort into layout than config settings
03-28-2020 05:18 AM - edited 03-28-2020 05:53 AM
Hi all,
If followed these steps :
xsct% INFO: [Hsi 55-2053] elapsed time for repository (C:/Xilinx/Vitis/2019.2/data\embeddedsw) loading 3 seconds connect attempting to launch hw_server ****** Xilinx hw_server v2019.2 **** Build date : Nov 6 2019 at 22:12:23 ** Copyright 1986-2019 Xilinx, Inc. All Rights Reserved. INFO: hw_server application started INFO: Use Ctrl-C to exit hw_server application ****** Xilinx hw_server v2019.2 **** Build date : Nov 6 2019 at 22:12:23 ** Copyright 1986-2019 Xilinx, Inc. All Rights Reserved. INFO: hw_server application started INFO: Use Ctrl-C to exit hw_server application INFO: To connect to this hw_server instance use url: TCP:127.0.0.1:3121 tcfchan#1 xsct% targets 1 whole scan chain (board power off) xsct% targets 2 PS TAP 3 PMU 4 PL 6 PSU 7 RPU (Reset) 8 Cortex-R5 #0 (RPU Reset) 9 Cortex-R5 #1 (RPU Reset) 10 APU (L2 Cache Reset) 11 Cortex-A53 #0 (APU Reset) 12 Cortex-A53 #1 (APU Reset) 13 Cortex-A53 #2 (APU Reset) 14 Cortex-A53 #3 (APU Reset) xsct% source C:/Xilinx/Vitis/2019.2/scripts/vitis/util/zynqmp_utils.tcl xsct% targets -set 5 xsct% Code 16 Time 1585397294047 Format {Invalid context} targets -set 6 xsct% rst -system xsct% after 3000 xsct% target -set 4 xsct% fpga -file C:/Test_fd/SF/HDMI_frm_bffr/HDMI_frame_buffer_wrapper.bit initializing 0% 0MB 0.0MB/s ??:?? ETA 5% 1MB 2.2MB/s ??:?? ETA 10% 1MB 1.9MB/s ??:?? ETA 14% 2MB 1.8MB/s ??:?? ETA 19% 3MB 1.7MB/s ??:?? ETA 24% 4MB 1.8MB/s ??:?? ETA 29% 5MB 1.7MB/s 00:07 ETA 34% 6MB 1.7MB/s 00:07 ETA 38% 7MB 1.7MB/s 00:06 ETA 43% 8MB 1.7MB/s 00:06 ETA 48% 8MB 1.7MB/s 00:05 ETA 53% 9MB 1.7MB/s 00:05 ETA 58% 10MB 1.7MB/s 00:04 ETA 62% 11MB 1.7MB/s 00:04 ETA 66% 12MB 1.7MB/s 00:03 ETA 72% 13MB 1.7MB/s 00:03 ETA 76% 14MB 1.7MB/s 00:02 ETA 81% 15MB 1.7MB/s 00:02 ETA 86% 15MB 1.7MB/s 00:01 ETA 91% 16MB 1.7MB/s 00:00 ETA 96% 17MB 1.7MB/s 00:00 ETA 100% 18MB 1.7MB/s 00:11 xsct% target -set 10 xsct% source C:/Test_fd/SF/HDMI_frm_bffr/ws/hdmi/hw/psu_init.tcl xsct% psu_init xsct% after 1000 xsct% psu_ps_pl_isolation_removal xsct% after 1000 xsct% psu_ps_pl_reset_config xsct% catch {psu_protection} 0 xsct% target -set 11 xsct% rst -processor xsct% Info: Cortex-A53 #0 (target 11) Stopped at 0xffff0000 (Reset Catch) xsct% dow C:/Test_fd/SF/HDMI_frm_bffr/ws/lucky/Debug/l.elf Downloading Program -- C:/Test_fd/SF/HDMI_frm_bffr/ws/lucky/Debug/l.elf section, .text: 0x00000000 - 0x00001523 section, .init: 0x00001540 - 0x00001573 section, .fini: 0x00001580 - 0x000015b3 section, .note.gnu.build-id: 0x000015b4 - 0x000015d7 section, .rodata: 0x000015d8 - 0x00001677 section, .rodata1: 0x00001678 - 0x0000167f section, .sdata2: 0x00001680 - 0x0000167f section, .sbss2: 0x00001680 - 0x0000167f section, .data: 0x00001680 - 0x00001e37 section, .data1: 0x00001e38 - 0x00001e3f section, .ctors: 0x00001e40 - 0x00001e3f section, .dtors: 0x00001e40 - 0x00001e3f section, .eh_frame: 0x00001e40 - 0x00001e43 section, .mmu_tbl0: 0x00002000 - 0x0000200f section, .mmu_tbl1: 0x00003000 - 0x00004fff section, .mmu_tbl2: 0x00005000 - 0x00008fff section, .preinit_array: 0x00009000 - 0x00008fff section, .init_array: 0x00009000 - 0x00009007 section, .fini_array: 0x00009008 - 0x00009047 section, .sdata: 0x00009048 - 0x0000907f section, .sbss: 0x00009080 - 0x0000907f section, .tdata: 0x00009080 - 0x0000907f section, .tbss: 0x00009080 - 0x0000907f section, .bss: 0x00009080 - 0x000090bf section, .heap: 0x000090c0 - 0x0000b0bf section, .stack: 0x0000b0c0 - 0x0000e0bf 0% 0MB 0.0MB/s ??:?? ETA 100% 0MB 0.1MB/s 00:00 Setting PC to Program Start Address 0x00000000 Successfully downloaded C:/Test_fd/SF/HDMI_frm_bffr/ws/lucky/Debug/.elf xsct% con Info: Cortex-A53 #0 (target 11) Running
It succeed, but using this I cannot see Hello world in serial window.
But if directly program it using Run as --> Launch on hardware. then I am getting the same error.
I am not getting further with this error. Please help.
Any ideas?
With regards,
Saini
03-30-2020 01:50 AM
The problem is the code you are trying to execute on the cortex a53 is at address 0x0:
xsct% Info: Cortex-A53 #0 (target 9) Stopped at 0xfffd4300 (Breakpoint)
xsct% Info: Cortex-A53 #0 (target 9) Running
xsct%
Downloading Program -- C:/Test_fd/SF/HDMI_frm_bffr/ws/hdmi_app/Debug/hdmi_app.elf
section, .text: 0x00000000 - 0x0000f493
section, .init: 0x0000f4c0 - 0x0000f4f3
section, .fini: 0x0000f500 - 0x0000f533
The debugger will read the address to be executed from the ELF and set the PC accordingly.
Is this correct? Have you an AXI BRAM controller in the PL at 0x0? If not, then change the linker
address to fix this (DDR or OCM), and try again
03-31-2020 04:16 AM
Hi @stephenm ,
Thank you for your guidance.
No, I am not using AXI BRAM controller.
If not, then change the linker address to fix this (DDR or OCM), and try again.
Yes, I checked then I find out that DDR was at 0x0 location. But even after changing it I am not able to run it and getting the same error.
Please see the screen shot of my address additor.
Is still something is wrong? But now nothing is at 0x0 address.
With Regards,
Saini
03-31-2020 05:04 AM
Can you change the linker to OCM and try again?
If this works, can you try a DDR test?
03-31-2020 07:03 AM
Hi @stephenm ,
I tried by changing the OCM/DDR in linker script with some random values: ...............{vitis_ws}/{app_name}/src/lscript.ld
But the result is same.
Original:
MEMORY { psu_ddr_0_MEM_0 : ORIGIN = 0x0, LENGTH = 0x7FF00000 psu_ddr_1_MEM_0 : ORIGIN = 0x800000000, LENGTH = 0x80000000 psu_ocm_ram_0_MEM_0 : ORIGIN = 0xFFFC0000, LENGTH = 0x40000 psu_qspi_linear_0_MEM_0 : ORIGIN = 0xC0000000, LENGTH = 0x20000000 }
Whatever value I change in origin of psu_ddr_0_MEM_0 or psu_ocm_ram_0_MEM_0, but the result is still the same.
Do you know What could I be doing wrong?
With regards,
Saini
03-31-2020 07:06 AM
I mean place all the sections into the OCM in your linker
04-01-2020 02:45 AM
Hi @stephenm ,
It worked with changing linker to OCM. As you mentioned before, I have also did one memory test and the result of it can be found below:
Do I always need to run this way by using ocm instead of ddr? What if I want to use ddr?
With Regards,
Saini
04-01-2020 04:46 AM
I suspect that there is an issue with your DDR config settings
04-01-2020 08:15 AM
Hi @stephenm ,
Thank you for your help. Yes, there was some issues with DDR config settings and now its working.
If you have some time, could you please explain your thought process how you narrowed down this error to DDR config settings?
It will also beneficial for beginner like me.
With Regards,
Saini
04-01-2020 09:27 AM
04-01-2020 09:29 AM
Also, can you mark this as solved?
05-27-2020 08:04 AM - edited 05-27-2020 08:05 AM
as Saini I am also stuck while trying the simple HelloWorld application.
As you suggested I replaced all sections into the OCM in my linker.
But still I get the same error message.
Here the XSCT terminal:
initializing
19% 1MB 2.1MB/s ??:?? ETA
35% 1MB 1.9MB/s ??:?? ETA
51% 2MB 1.8MB/s ??:?? ETA
66% 3MB 1.7MB/s ??:?? ETA
85% 4MB 1.7MB/s ??:?? ETA
100% 5MB 1.7MB/s 00:03
Info: Cortex-A53 #0 (target 10) Running
xsct%
Downloading Program -- D:/Mercury_XU5_PE1_CG_EG/Mercury_XU5_PE1/HelloWorld2/Debug/HelloWorld2.elf
section, .text: 0xfffc0000 - 0xfffc1523
section, .init: 0xfffc1540 - 0xfffc1573
section, .fini: 0xfffc1580 - 0xfffc15b3
section, .note.gnu.build-id: 0xfffc15b4 - 0xfffc15d7
section, .rodata: 0xfffc15d8 - 0xfffc1677
section, .rodata1: 0xfffc1678 - 0xfffc167f
section, .sdata2: 0xfffc1680 - 0xfffc167f
section, .sbss2: 0xfffc1680 - 0xfffc167f
section, .data: 0xfffc1680 - 0xfffc1e37
section, .data1: 0xfffc1e38 - 0xfffc1e3f
section, .ctors: 0xfffc1e40 - 0xfffc1e3f
section, .dtors: 0xfffc1e40 - 0xfffc1e3f
section, .eh_frame: 0xfffc1e40 - 0xfffc1e43
section, .mmu_tbl0: 0xfffc2000 - 0xfffc200f
section, .mmu_tbl1: 0xfffc3000 - 0xfffc4fff
section, .mmu_tbl2: 0xfffc5000 - 0xfffc8fff
section, .preinit_array: 0xfffc9000 - 0xfffc8fff
section, .init_array: 0xfffc9000 - 0xfffc9007
section, .fini_array: 0xfffc9008 - 0xfffc9047
section, .sdata: 0xfffc9048 - 0xfffc907f
section, .sbss: 0xfffc9080 - 0xfffc907f
section, .tdata: 0xfffc9080 - 0xfffc907f
section, .tbss: 0xfffc9080 - 0xfffc907f
section, .bss: 0xfffc9080 - 0xfffc90bf
section, .heap: 0xfffc90c0 - 0xfffe20bf
section, .stack: 0xfffe20c0 - 0xffffc0bf
100% 0MB 0.2MB/s 00:00
Setting PC to Program Start Address 0xfffc0000
Successfully downloaded D:/Mercury_XU5_PE1_CG_EG/Mercury_XU5_PE1/HelloWorld2/Debug/HelloWorld2.elf
Info: Cortex-A53 #0 (target 10) Stopped at 0xffff0000 (Reset Catch)
xsct% Info: Cortex-A53 #0 (target 10) Stopped at 0x0 (Cannot resume. Cannot read 'pc'. Cannot read 'r0'. Instruction transfer timeout)
xsct% Info: Cortex-A53 #0 (target 10) Running
xsct%
12-28-2020 01:16 AM
I have the same problem.
if I do not use FSBL, it can work.
When I use FSBL in debug configuration, it cann't debug.
the logs have three error:
1. WARN : Exit breakpoint of FSBL (XFsbl_Exit) is not hit within allocated wait time of '60' seconds
2. Cannot resume. Cannot read 'pc'. Cannot read 'r0'. Instruction transfer timeout
3. Memory write error at 0x0. Instruction transfer timeout
