xil_tour
Data transfer example, no read no write
When running the vanilla data transfer example with soft/hard simulation, I'm surprised to see that no data is actually transferred:
TEST PASSED
INFO: [SDx-EM 22] [Wall clock time: 15:34, Emulation time: 0.00267726 ms] Data transfer between kernel(s) and global memory(s)
dummy_kernel_1:m_axi_gmem0          RD = 0.000 KB               WR = 0.000 KB
dummy_kernel_1:m_axi_gmem1          RD = 0.000 KB               WR = 0.000 KB
The "max memory ports" option is checked.
hongh
Hi, @xil_tour ,
"Data Transfer" example illustrates several ways to use the OpenCL API to transfer data to/from the FPGA.
The "dummy" kernel is not called by the host, so there is no data transferring between global memory and kernel.
brucey
This does seem that there's no data transfer between kernel and global memory.
Is it a Xilinx example?
brucey
xil_tour
Yes, it's the unmodified "data transfer" example from SDx 2018.2.
xil_tour
Bump.
hongh
Hi, @xil_tour ,
xil_tour
Ok, thanks for your time.
