msaideroglu
Digilent Boards Support for Vitis
I am using Nexys Video Board. Is there pre-defined platfrom files for Nexys Video or other Digilent boards for Vitis platform to plug-play design process. Just like saving digilent board files to Vivado boards file path? Thanks..
nutang
Hi @msaideroglu
No. Vitis provides only Xilinx evaluation board platforms. Here is the github page for platforms
https://github.com/Xilinx/Vitis_Embedded_Platform_Source/tree/master/Xilinx_Official_Platforms
If you want to work on Nexys Video board. You need to create a custom platform.
1. For standalone application -
  • Create Vivado design and generate XSA
  • Create a platform project in Vitis using this XSA
  • Create application from templates to get started
2. Linux based platform / Acceleration platform
  • Create a petalinux project with XSA and build linux boot files
  • Create platform project in Vitis for linux domain
  • Create application project for linux domain to get started
Reference -
https://github.com/Xilinx/Vitis-In-Depth-Tutorial/tree/master/Vitis_Platform_Creation
Best Regards,
Nutan
nutang
Hi @msaideroglu
Reference -
Best Regards,
Nutan
msaideroglu
Thank you for your clear explanation. I have one more question. Are all Zynq applications applicable to MicroBlaze? For instance, a DMA design with Zynq can be done in same way with MicroBlaze? Because there are a lot of embedded design tutorials with Zynq, but not with MB.
