wjh12345
ERROR: [VPL 17-179] Fork failed: Cannot allocate memory
I used the official example of vitis.
https://github.com/Xilinx/Vitis-Tutorials/tree/master/docs/Pathway3/reference-files/src
https://github.com/Xilinx/Vitis-Tutorials/blob/master/docs/Pathway3/BuildingAnApplication.md
https://github.com/Xilinx/Vitis-Tutorials/blob/master/docs/Pathway3/Emulation.md#emulation-configuration-files
I used xilinx_u200_xdma_201830_2 platform for hardware simulation, and the following error occurred during the hardware link
hongh
Please confirm there is enough memory left in your server for your run.
hongh
