Error:No devices found(KCU1500)
I install the KCU1500
But now I can't see the device by the ./xbsak list:
this is the process,Who can tell me where's the problem:IMG_20190908_202235.jpgIMG_20190908_202422.jpgIMG_20190908_203058.jpg
please check the if the driver is loaded succesfully
lspci -vd 10ee:
Thx
Min
lspci -vd 10ee:
Thx
Min
lspci -d 10ee:01.00.0 Memory controller :Xilinx Corporation Device 8083
Is it Correct?
And what's the problem with the xbsak?
please use -vd  option
00:09.0 Serial controller: Device 1ded:1004 (prog-if 01 [16450])
Subsystem: Device 1ded:4342
Physical Slot: 9
Flags: bus master, fast devsel, latency 0, IRQ 10
Memory at fc000000 (32-bit, non-prefetchable) [size=16M]
Memory at fe090000 (32-bit, non-prefetchable) [size=64K]
Memory at 1000000000 (64-bit, prefetchable) [size=64G]
Capabilities: <access denied>
Kernel driver in use: xocl
Kernel modules: xocl
the red color line mean the driver is loaded proberly
if not check dmesg, find the failure reason
Thx
Min
I don't konw if I program the FPGA correctly,I just program the card with primary.mcs and Secondary.mcs,is it the correct program?But I can‘t’ detect my device use lspci -vd 10ee:,So which program should I reflash to the card?
Did you power cycle the server after the program?
I solved it,I program the proper program ,then I can detect it!
