Error : Run 'synth_1' has not been launched
I am facing following error during build_system.
Note : vivad_hls phase is successful, this error occurs during vivado phase.
ERROR: [Common 17-69] Command failed: Run 'synth_1' has not been launched. Unable to open
@ywu
I will send a private mail on this.
Hi @kaliuday
Please post the complete vivado log.
Thanks,Vijay
Hi @vijayak
PFA, log here.
synth_1 completes and runme.log is empty as such.
Hi @kaliuday
Can you please try creating the project from scratch and see if that helps?
Thanks,Vijay
sure I will try that out.
Hi @kaliuday
Do you have any updates?
Thanks,Vijay
Hi Vijay,
SDAccel version 2015.4
I created a new project and built again still error persists. FYI, this is a OpenCL kernel with single thread of execution.
To verify the behaviour, I have ported it as HLS kernel, build goes through and passes timing. During the execution it hangs.
(FPGA configured with DSA 2.1 firmware)
SDAccel version 2015.3 :
I built both HLS & OpenCL kernels using 2015.3, build goes through fine and timing passes for both the kernels. I could execute the kernels successfully on board. (FPGA configured with DSA 2.0 firmware)
@kaliuday
Who is your Xilinx contact? Please work with him/her and copy me on the email (ywu at xilinx dot com).
@kaliuday wrote:
Hi Vijay,
Cheers,
Jim
@ywu
I encountered two similar variants of this issue with 2016.1
a) Like kaliuday:
synth_1 runme.log empty
Fresh compile helped.
b) Vivado stuck at synth_1:
Vivado was running for ~48h; when I investigated it, it hat only 2-3% CPU load and no IO going on.
The logs in synth_1 were empty, all other kernels where done.
Notably, both were very large designs, at least 20% larger than the largest successfully generated designs.
I am experiencing this exact same issue, building with Vivado 2016.3... tail of the build log is pasted below, with the same message. At the moment I am stuck with the 2016.3 version, pending an upgrade; but can I ask what the solution to this was? The reply marked as "accepted answer" amounts to "I'll send you a private email"... which doesn't help the rest of the audience of a forum.
Eldridge
[Wed Jan 31 14:49:19 2018] Launched synth_1...
Run output will be captured here: /home/jenkins/jobs/<redacted>/runme.log
launch_runs: Time (s): cpu = 00:00:08 ; elapsed = 00:00:14 . Memory (MB): peak = 1939.145 ; gain = 0.000 ; free physical = 130 ; free virtual = 4835
[Wed Jan 31 14:49:19 2018] Waiting for synth_1 to finish...
[Wed Jan 31 15:49:59 2018] synth_1 finished
wait_on_run: Time (s): cpu = 01:00:36 ; elapsed = 01:00:40 . Memory (MB): peak = 1939.145 ; gain = 0.000 ; free physical = 277 ; free virtual = 5530
while executing
"source implement.tcl"
(file "./masterBuilder.tcl" line 49)
INFO: [Common 17-206] Exiting Vivado at Wed Jan 31 15:49:59 2018...
Build step 'Execute shell' marked build as failure
Archiving artifacts
Recording test results
Finished: FAILURE
How is this marked as a solution?
I am having the same issue when attempting to export IP with Vivado HLS 2018.3. The runme.log file is never created with no indication of why the synthesis has failed to launch.
We use Xilinx Vivado 2017.4, Family Kintex7 and Speedgoat Hardware. The problem is the same. What is the solution?
Running on Vivado HLS 2019.1.1 on Ubuntu 18.04, same problem. This thread should not have a solution marked, since the accepted "solution" is not a solution at all.
Couldn't see how to edit posts, but it turns out my problem was due to my license server being misconfigured, so Vivado couldn't find a license to do the sythensis run. Fixed that and now it works.
