wd-hyj
Error building xfOpencv on zed-zynq-xc7z020
I am building an xfOpenCV example on zed-zynq-xc7z020 in Sdx 2018.2 on Ubuntu16.04 ,but failed .Here is my settings:
and here is the building error information: In my opinion, the error is due to my libs----libgtk-3.so.0,libcairo.so.2,etc are 64bit .
Preliminary link application ELF
/opt/Xilinx/SDK/2018.2/gnu/aarch32/lin/gcc-arm-linux-gnueabi/bin/../lib/gcc/arm-linux-gnueabihf/7.2.1/../../../../arm-linux-gnueabihf/bin/ld: warning: libgtk-3.so.0, needed by /opt/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch32/lib/libopencv_highgui.so, not found (try using -rpath or -rpath-link)
/opt/Xilinx/SDK/2018.2/gnu/aarch32/lin/gcc-arm-linux-gnueabi/bin/../lib/gcc/arm-linux-gnueabihf/7.2.1/../../../../arm-linux-gnueabihf/bin/ld: warning: libgdk-3.so.0, needed by /opt/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch32/lib/libopencv_highgui.so, not found (try using -rpath or -rpath-link)
/opt/Xilinx/SDK/2018.2/gnu/aarch32/lin/gcc-arm-linux-gnueabi/bin/../lib/gcc/arm-linux-gnueabihf/7.2.1/../../../../arm-linux-gnueabihf/bin/ld: warning: libcairo.so.2, needed by /opt/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch32/lib/libopencv_highgui.so, not found (try using -rpath or -rpath-link)
/opt/Xilinx/SDK/2018.2/gnu/aarch32/lin/gcc-arm-linux-gnueabi/bin/../lib/gcc/arm-linux-gnueabihf/7.2.1/../../../../arm-linux-gnueabihf/bin/ld: warning: libgdk_pixbuf-2.0.so.0, needed by /opt/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch32/lib/libopencv_highgui.so, not found (try using -rpath or -rpath-link)
/opt/Xilinx/SDK/2018.2/gnu/aarch32/lin/gcc-arm-linux-gnueabi/bin/../lib/gcc/arm-linux-gnueabihf/7.2.1/../../../../arm-linux-gnueabihf/bin/ld: warning: libgobject-2.0.so.0, needed by /opt/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch32/lib/libopencv_highgui.so, not found (try using -rpath or -rpath-link)
/opt/Xilinx/SDK/2018.2/gnu/aarch32/lin/gcc-arm-linux-gnueabi/bin/../lib/gcc/arm-linux-gnueabihf/7.2.1/../../../../arm-linux-gnueabihf/bin/ld: warning: libglib-2.0.so.0, needed by /opt/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch32/lib/libopencv_highgui.so, not found (try using -rpath or -rpath-link)
/opt/Xilinx/SDK/2018.2/gnu/aarch32/lin/gcc-arm-linux-gnueabi/bin/../lib/gcc/arm-linux-gnueabihf/7.2.1/../../../../arm-linux-gnueabihf/bin/ld: warning: libjpeg.so.62, needed by /opt/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch32/lib/libopencv_imgcodecs.so, not found (try using -rpath or -rpath-link)
/opt/Xilinx/SDK/2018.2/gnu/aarch32/lin/gcc-arm-linux-gnueabi/bin/../lib/gcc/arm-linux-gnueabihf/7.2.1/../../../../arm-linux-gnueabihf/bin/ld: warning: libwebp.so.6, needed by /opt/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch32/lib/libopencv_imgcodecs.so, not found (try using -rpath or -rpath-link)
/opt/Xilinx/SDK/2018.2/gnu/aarch32/lin/gcc-arm-linux-gnueabi/bin/../lib/gcc/arm-linux-gnueabihf/7.2.1/../../../../arm-linux-gnueabihf/bin/ld: warning: libpng16.so.16, needed by /opt/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch32/lib/libopencv_imgcodecs.so, not found (try using -rpath or -rpath-link)
/opt/Xilinx/SDK/2018.2/gnu/aarch32/lin/gcc-arm-linux-gnueabi/bin/../lib/gcc/arm-linux-gnueabihf/7.2.1/../../../../arm-linux-gnueabihf/bin/ld: warning: libtiff.so.5, needed by /opt/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch32/lib/libopencv_imgcodecs.so, not found (try using -rpath or -rpath-link)
/opt/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch32/lib/libopencv_imgcodecs.so:对‘png_set_filter@PNG16_0’未定义的引用
/opt/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch32/lib/libopencv_imgcodecs.so:对‘png_get_IHDR@PNG16_0’未定义的引用
/opt/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch32/lib/libopencv_imgcodecs.so:对‘png_create_read_struct@PNG16_0’未定义的引用
/opt/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch32/lib/libopencv_highgui.so:对‘g_time_val_add’未定义的引用
The following is my questions:
1. We can see gcc-arm-linux-gnueabi is 32 bit from the error info "/opt/Xilinx/SDK/2018.2/gnu/aarch32/lin/gcc-arm-linux-gnueabi/bin/..",right ? So all of my libraries used in the project must be 32 bit libraries ?
2. If the libraries to be used in the project are 64 bit , from the info "/opt/Xilinx/SDK/2018.2/gnu/aarch32/lin/gcc-arm-linux-gnueabi/bin/.." , do i have only two choices ? either change the libs from 64 bit to 32 bit or change the gcc-arm-linux-gnueabi to 64 bit (does it exist ?) ?
wd-hyj
wd-hyj
tuanho27
Hi @wd-hyj, could you share the way you solve this issue?
Thank you very much!
tuanho27
Oh, thanks, I fixed it
Just make it correct in SDS++ Linker > Libraries (add lib name) and copy the lack of lib*.so (after install) to the reference libraries, remember to link the name
zxbzsb
Hello, what you mean is to download the missing library and put it in the appropriate location. As shown in the picture, it is my problem.1.png2.png
@zxbzsb
Oh I had the same issue, given that I already have it pointing to the directory with the correct .so files in
FYI I'm working on an Avnet Ultra96 board
zxbzsb
What you mean is to download the relevant so file  and put it in the appropriate location.
