JeMin
Error in launching vitis IDE
Hello! I'm having a problem here..
I'm in Windows10 and using Vivado 2020.1 and Xilinx Vitis 2020.1
I'm trying to do 'Hello world' experiment.
First, I created block design
Second, Generate Output Products
Third, Vreate HDL wapper
Fourth, generate bitstream
Fifth Export hardware Platform including bitstream
Finally, I try to Export Hardware Platform in Tools menu.
I made directory to ./my project_folder/workspace and clicked Launch.
But there is error here.
The log file is following:
!SESSION 2020-10-20 13:50:42.036 -----------------------------------------------
eclipse.buildId=2020.1
java.version=9.0.4
java.vendor=Oracle Corporation
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=ko_KR
Command-line arguments: -os win32 -ws win32 -arch x86_64
!ENTRY com.xilinx.sdk.utils 4 0 2020-10-20 13:51:09.037
!MESSAGE FrameworkEvent ERROR
!STACK 0
java.util.zip.ZipException: Exception in opening zip file: C:\Users\jjmfi\.Xilinx\Vitis\2020.1\org.eclipse.osgi\29\0\.cp\lib\log4j-1.2.17.jar
at org.eclipse.osgi.framework.util.SecureAction.getZipFile(SecureAction.java:317)
at org.eclipse.osgi.storage.bundlefile.ZipBundleFile.getZipFile(ZipBundleFile.java:132)
at org.eclipse.osgi.storage.bundlefile.ZipBundleFile.lockOpen(ZipBundleFile.java:79)
at org.eclipse.osgi.storage.bundlefile.ZipBundleFile.getEntry(ZipBundleFile.java:288)
at org.eclipse.osgi.internal.loader.classpath.ClasspathEntry.loadManifest(ClasspathEntry.java:226)
at org.eclipse.osgi.internal.loader.classpath.ClasspathEntry.<init>(ClasspathEntry.java:75)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.createClassPathEntry(ModuleClassLoader.java:260)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.createClassPathEntry(ClasspathManager.java:340)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.getClasspath(ClasspathManager.java:292)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.addStandardClassPathEntry(ClasspathManager.java:209)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.addClassPathEntry(ClasspathManager.java:201)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findClassPathEntry(ClasspathManager.java:184)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.buildClasspath(ClasspathManager.java:163)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.<init>(ClasspathManager.java:92)
at org.eclipse.osgi.internal.loader.EquinoxClassLoader.<init>(EquinoxClassLoader.java:43)
at org.eclipse.osgi.internal.loader.BundleLoader.createClassLoaderPrivledged(BundleLoader.java:340)
at org.eclipse.osgi.internal.loader.BundleLoader.getModuleClassLoader(BundleLoader.java:257)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:392)
at org.eclipse.osgi.internal.loader.sources.SingleSourcePackage.loadClass(SingleSourcePackage.java:36)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:466)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:419)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:411)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:150)
at java.base/java.lang.ClassLoader.loadClass(Unknown Source)
at com.xilinx.ide.application.ui.Application.checkInstanceLocation(Application.java:219)
at com.xilinx.ide.application.ui.Application.start(Application.java:72)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:388)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:243)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.base/java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:656)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:592)
at org.eclipse.equinox.launcher.Main.run(Main.java:1498)
If there is any solution I can try please let me know.
Thank you very much
stephenm
In your local, or linux machine. Can you try remove the .Xilinx\Vitis folder and try again?
stephenm
olupj
@JeMin
I was able to get past this with a new workspace. Not elegant but works.
JeMin
Thank you so much! It worked very well
JeMin
Thank you for the reply!
