hanqiu
Error using sds++
Hi, I've installed SDSoC and try to build some programs using makefile in the samples/mmult directory. But it terminates with some errors. I'm using ubuntu 16.04 and SDSoD 2016.2. Please help! Thank you!
sds++ -sds-pf zc702 -sds-hw mmult_accel mmult_accel.cpp -sds-end -poll-mode 1 -Wall -O3 -c -MMD -MP -MF"mmult.d" mmult.cpp -o mmult.o
xsltproc: error while loading shared libraries: libgcrypt.so.11: cannot open shared object file: No such file or directory
Usage: /usr/bin/which [-a] args
Illegal option -g
    while executing
"exec which [apc_get_global APCC_TOOLCHAIN]-g++"
    (procedure "sdscc_set_toolchain_config" line 27)
    invoked from within
"sdscc_set_toolchain_config "zynq" "linux" "cortex-a9" "arm-linaro""
    invoked from within
"if { [string match $target_os_type "linux"] } {
  if {[string first "zcu102" $xsd_platform] >= 0} {
    apc_set_global APCC_PROC_INSTANCE psu_cortexa5..."
    (file "/opt/Xilinx/SDSoC/2016.2/bin/xdcc.tcl" line 2984)
Makefile:65: recipe for target 'mmult.o' failed
make: *** [mmult.o] Error 1
sskalick
Hi hanqiu,
Please note SDSoC only supports Ubuntu Linux 14.04.3 LTS (64-bit) per the release notes here: http://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_2/ug1185-sdsoc-release-notes.pdf
Sam
sskalick
Hi hanqiu,
Sam
kodukulav
@sskalick ,
It looks like SDSoC is now supported on Ubuntu 16.04 per the release notes. I'm still getting the same error. Can you help me fix it?
Venky
