curlywei
Error when build FSBL for zynq-7000 using xsct
Here is my tcl script for build
set kAPPName "xvc_fsbl"
set kPlatformName "${kAPPName}_pf"
set kDomainName "${kAPPName}_dom"
set kXSAFilePath "xvc_server_hw/xvc_system_top.xsa"
set kOutputDir "xvc_server_os"
setws ${kOutputDir}
platform create \
  -name ${kPlatformName} \
  -hw ${kXSAFilePath}
domain create \
  -name ${kDomainName} \
  -os standalone \
  -proc ps7_cortexa9_0
platform generate
app create \
  -name ${kAPPName} \
  -platform ${kPlatformName} \
  -domain ${kDomainName} \
  -template {Zynq FSBL}
The xsa file  "xvc_system_top.xsa" I bring from vivado command
write_hw_platform -fixed -include_bit -force -verbose xvc_system_top.xsa
when I run
$ xsct -eval source ../src/os/gen_fsbl.tcl
I got this error message
Specified template name Zynq FSBL is not valid for configuration. Reason: This application requires xilffs library in the Board Support Package.. List of valid names are Hello World, Memory Tests, Zynq DRAM tests, Peripheral Tests, Dhrystone, Empty Application.
    while executing
"error [dict get $msg err]"
    (procedure "xsdk_eval" line 15)
    invoked from within
"xsdk_eval $chan "XSDx" createAppFromPlatform "o{$fmt}" e [list $data]"
    (procedure "app" line 382)
    invoked from within
"app create \
  -name ${kAPPName} \
  -template {Zynq FSBL}"
    (file "../src/os/gen_fsbl.tcl" line 20)
I thought the reason is because I specify "part-name" instead of "BOARD_PART" when I build vivado project, I'm not sure.
Has any suggestion?
pvempati
Hi @curlywei ,
The above error is expected. This is due FSBL application requires xilffs library. which is not available in this domain.
Please use the below command after creation of the domain to enable the xilffs library in the domain. then run the platform generate command like below
bsp setlib xilffs
platform generate
then... create the application
app create
Please let me know if you see any issue again.
Thanks & Regards,
Praveen Kumar. V
pvempati
Hi @curlywei ,
bsp setlib xilffs
platform generate
app create
Thanks & Regards,
Praveen Kumar. V
