baring42read
Error when extern "c" is used in vitis
So I have successfully tested a couple of programs  the vitis using zcu102, including the vector addition. I  wanted to try the same for a custom kernel as stated in this document https://xilinx.github.io/Vitis-Tutorials/2020-1/docs/my-first-program/cpp_kernel.html  and got this error
ERROR: [v++ 207-2851] unknown linkage language:
This error points to the extern "c" around the kernel.
What could be the problems?
Thank you
kmorris
Is the file extension you are using cpp? Could you show how you have written the code?
Please don’t forget to reply, kudo, and accept as solution!
baring42read
I think  I missed the #include <CL/cl2.hpp>. It seemed to have been resolved.
