s.corda
HW target compile only host code Vitis
Let's assume I build the HW target on Vitis. Then, I realize I want to change something in the c++ code of host application. How can I build the HW target without building again the kernel binary?
hongh
Please refer to UG1393 for the below content:
Building the Host Program / Compiling and Linking for x86
