mhmontazeri61
HWEmulation without programming xclbin in SDAccel
Hi everybody,
I have a U200 card and i need add some blocks in Vivado to an existing SDAccel code. For this test, i need program my integrated bit file in Vivado and run related application in SDAccel without programming xclbin file of original existing program in SDAccel during running host exe file. Is this a common process or is not a normal method? My main application includes reading data from embedded qsfp ports in U200 that it seems is not accessible via SDAccel. So, at the first attempt, my implementation procedure is adding qsfp port in Vivado block design to existing block generated by SDAccel code.
Best Regards
mhmontazeri61
hongh
Such flow for SDAccel is not supported.
The static logic of the platform cannot be modified.
We plan to develop new DSA for U200 to support qsfp ports in the near future.
