stzog
Host code for many kernels calls
Hi to all!
I need some more Vitis examples with more than one kernels accelerated except from this one
 https://github.com/Xilinx/Vitis_Accel_Examples/tree/master/host/concurrent_kernel_execution
I want to see the host code structure(if possible in vector add example based...) for calling different kernels.
thanks in advance!
bchebrol
Hi @stzog ,
Can you check the following kernel_swap design which had multiple kernels.
https://github.com/Xilinx/Vitis_Accel_Examples/tree/master/sys_opt/kernel_swap
Vishnu
stzog
@bchebrol
I have already checked this but my board does not support it.(zcu102)
Any other example please?
Thanks for your reply!
