How Vitis host can read an image
Hi to all!
Is it possible to make the host in a Vitis accel example, to read an image from my HD as an input?
If so how can i achieve it???I am trying to build in Vitis a laplacian edge detector.
Thanks in advance.
Hi @stzog ,
you can use the following design as reference where bmp files are used as input:
1. https://github.com/Xilinx/Vitis_Accel_Examples/tree/master/cpp_kernels/critical_path
2. https://github.com/Xilinx/Vitis_Accel_Examples/tree/master/cpp_kernels/gmem_2banks
3. https://github.com/Xilinx/Vitis_Accel_Examples/tree/master/cpp_kernels/custom_datatype
Vishnu
This would need to be done in your HW platform.
For example:
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842083/HDMI+FrameBuffer+Example+Design+2018.1
Then set the AXI PFM properties on this interface
@stephenm
I just want to load an image(.bmp) from my hard disk to vitis Ηost as input to the accelerated kernel.
Is that possible?The host to read from hard drive an image directly?
Thanks in advance.
Hi @stzog ,
Vishnu
