austinkim
How can I insert "place option" in vitis flow ? (insert -no_bufg_opt)
Hello.
I am currently getting the following error at high freq 250MHz. (but, 100MHz fine.)
I think bufg has a cause, so I want to apply the no_bufg_opt option.
How can I add the "-no_bufg_opt" option to the place step in vitis flow? (such as v++ link option)
Thank you.
austinkim
This sentence is fine.
--vivado.prop run.impl_1.{'STEPS.PLACE_DESIGN.ARGS.MORE OPTIONS'}={-no_bufg_opt}
Thank you for your attention and reply.
hongh
Please refer to "Using the -vivado and -advanced Options" in the below doc to add options for place_design of VPL.
https://www.xilinx.com/html_docs/xilinx2020_2/vitis_doc/buildingdevicebinary.html#npr1602449118702
austinkim
Thank you for your reply.
I don't know how to apply "-no_bufg_opt" in PLACE_DESIGN.
I tried some method, but not worked.
try 1. added option in v++ link.
--vivado.prop run.impl_1.{STEPS.PLACE_DESIGN.ARGS.MORE OPTIONS}={-no_bufg_opt}
This command was ERROR.
try 2. used   "v++ --vivado.prop run.impl_1.STEPS.PLACE_DESIGN.TCL.PRE=place_option.xdc"
<place_option.xdc>
place_design -directive Explore -no_bufg_opt
"try 2" was working. but, PLACE_DESIGN ran twice.
1st. place_design -directive Explore -no_bufg_opt
2nd. place_design -directive Explore
This command was ERROR, it is because PLACE_DESIGN ran twice.
In 1st step is right. (I want to do 1st step only.)
So, how can I apply "-no_bufg_opt" exactly
Please let me know.
Thank you.
hongh
What's the error message for "try 1"?
austinkim
A detailed description of "try 1" is as follows.
ERROR Message is here.
ERROR: [v++ 60-602] Source file does not exist: /user2/austin/vitis_aws/aws-fpga/Vitis/examples/210225_aws_startrek_2x/startrek_mvp/Hardware/OPTIONS}={-no_bufg_opt}
INFO: [v++ 60-1662] Stopping dispatch session having empty uuid.
I don't know why occur this ERROR.
Please check my error and thank you for your reply.
hongh
Please try the below option:
--vivado.prop "run.impl_1.STEPS.PLACE_DESIGN.ARGS.{MORE OPTIONS}={-no_bufg_opt}"
austinkim
Ah....   ""  The symbol is very important.
As you mentioned, I added that symbol.
The error that occurred in the tool has disappeared and is being implemented.
When I confirm that it works, I will press kudo.
austinkim
After your guide, I checked another error.
===================== ERROR Message ======================
ERROR: [VPL 60-773] In'/user2/austin/vitis_aws/aws-fpga/Vitis/examples/210225_aws_startrek_2x/startrek_mvp/Hardware/binary_container_1.build/link/vivado/vpl/runme.log', caught Tcl error: ERROR: [Common 17-158]'name' can only be specified once.
WARNING: [VPL 60-732] Link warning: INFO: Platform does not require extraction of debug/profile metadata.
ERROR: [VPL 60-704] Integration error, Failed to source Vivado impl properties. The project is'prj'. The internal Vivado impl script is'scripts/_vivado_impl_props.tcl'. The script was generated by VPL. An error stack with function names and arguments may be available in the'vivado.log'.
ERROR: [VPL 60-1328] Vpl run'vpl' failed
ERROR: [VPL 60-806] Failed to finish platform linker
INFO: [v++ 60-1442] [11:02:12] Run run_link: Step vpl: Failed
Time(s): cpu = 00:00:13; elapsed = 00:10:55. Memory (MB): peak = 1436.824; gain = 0.000; free physical = 54775; free virtual = 145671
ERROR: [v++ 60-661] v++ link run'run_link' failed
ERROR: [v++ 60-626] Kernel link failed to complete
ERROR: [v++ 60-703] Failed to finish linking
INFO: [v++ 60-1653] Closing dispatch client.
make: *** [makefile:82: binary_container_1.xclbin] Error 1
in runme.log
This is my link option
Please check my error.
austinkim
hongh
Sorry for the typo:
--vivado.prop "run.impl_1.{STEPS.PLACE_DESIGN.ARGS.MORE OPTIONS}={-no_bufg_opt}"
