goahead97
How do I get rid of "ERROR: [v++ 60-602] Source file does not exist: /media/x/forVitis/workspace_1/vadd_system_hw_link/Emulation-HW/binary_container_1.xclbin" while building Emulation-HW?
Hello
When I try to build the project "Emulation-HW" for the  example "vadd_system" in Xilinx Vitis IDE v2020.2.0 (64-bit), I get the following error:
You can find in attachment the content of the folder /media/x/forVitis/workspace_1/vadd_system_hw_link/Emulation-HW
How do I get rid of this error?
yangc
It seems you don't generate the xclbin file. Do you modify something in the project?
goahead97
Hello
So far as I know I did not modify anything in the project yet. But may be, unknowingly, I touched something I should not.
goahead97
I just created a new project. This time I called it vadd2. I tried to build it in Emulation-HW configuration again and I got the same error once again.
ERROR: [v++ 60-602] Source file does not exist: /media/x/forVitis/workspace_1/vadd2_system_hw_link/Emulation-HW/binary_container_1.xclbin
yangc
Can you share the project?
akasat
Based on the earlier message, looks like somehow questa simulator is being used for hw_emu run. Can you double check your settings. And do you have questa/modelsim license?
ERROR: Unable to load Tcl app xilinx::modelsim.
venkatp
Based on the console errors, its hard to suspect the root cause of the issue, it is really appreciated if you share the vivado.log and runme.log that are specified in the console. Those logs may have the more elaborated error info.
And we suspect you are using Linux OS. As an initial triage, could you try to Delete $HOME/.Xilinx/Vivado/<vivado_version>/XilinxTclStore and re-launch the Vitis and re-run the design.
