lygw
How to check the frequency of HBM and kernel?
I find that the time I calculate out does not match the real running time so I want to check the frequency of HBM and kernel. Where can I check the frequency?
hongh
Add -R2 option in V++ link stage and check the below dir:
Ex: ..../project_name/Hardware/binary_container_1.build/link/vivado/vpl/prj/prj.runs/impl_1
hongh
Could you try to open the opt.dcp or routed.dcp and check the result of report_timing_sumamry?
lygw
Thank you for answer! And...would you like to tell me the paths to these two files?
hongh
lygw
Sorry to bother again... would you like to tell me which clock is related to HBM and which one is related to my kernel?
Is the clk_out1_pfm_top_clkwiz_hbm_aclk_0 clocking the HBM?
Is the clk_out1_pfm_top_clkwiz_kernel_0 clocking my kernel?
