ea872@csus.edu
How to force write_bitstream after timing failure
I am expecting the design to fail for timing with little slack but i still want to generate bitstream but the SDx tool Errors out during bitstream generation. How can i force the bitstream dispite the timing issue?
Thank you,
Eddie
hemangd
Hi ea872@csus.edu ,
What errors are you facing? Provide a snapshot of it.
Generally, tool does not throw errors on timing violations but warnings or critical warnings.
Despite, use write_bitstream -force
hemangd
ea872@csus.edu
Hi Hemangd,
for some reason the write_bitstream is failing due to the timing failure.
Not sure what is causing this.
Eddie
Screen Shot 2019-08-11 at 11.06.02 PM.pngScreen Shot 2019-08-11 at 11.07.09 PM.png
hemangd
Hi ea872@csus.edu ,
Have a look into this thread. It may help you. https://forums.xilinx.com/t5/SDSoC-Environment-and-reVISION/SDSoC-timing-error/td-p/913446
hemangd
ea872@csus.edu
Hi Hemangd,
I am currently using a Makefile not the GUI interferface, would the fix mentioned in the thread work in my case? Also should i use the implementation or synthesis fix mentioned in the post? Lastly what would be the correct syntax for using this paramater mentioned "parameter: param:compiler.skipTimingCheckAndFrequency Scaling=1".
I also included the make file i am currently using so you can get a better idea of the method i am using.
Can these options be passed in through through a tcl file for example the sds.tcl file?
Eddie
