lzhao
How to generate multiple elf files?
Hi all,
I am currently working on a projct using Vitis-AI. We have a working model based on tensorflow. At step quantization, we got warnning that indicating some of the layers is not supported by Vitis, but still generated the pb files. At compiling step we got error message and no elf file generated.
According to Vitis AI user manual, on page 66,
"For each model, all its DPU ELF files generated by VAI_C should be linked together into one unique DPU shared library in the naming format of libdpumodelModelName.so.", the compiler could generate multiple elf files. So I am wondering in our case, when we do compilation, it should created several elf files, which then can be used in the programming step(using c++ api or python api).
My question is how to generate multilple elf files? Thanks!
