definelicht
How to install VCU1525 with SDAccel 2018.3?
SDAccel 2018.3 has completely changed how the OpenCL runtime works.
I've managed to migrate our build system to use XRT, but it seems DSAs/platforms have also vanished from the SDx directory.
(I ticked Virtex UltraScale+ in the installer)
Furthermore, the installation guide for VCU1525 has vanished, the link just redirects to the product page, and when searching for documentation, no results are found (??).
Where are the DSAs for SDAccel 2018.3?
What happened to xbinst, and what should we use instead?
What happened to the installation guide for VCU1525?
For obvious reasons, 2018.3 is currently unusable for us.
Thanks in advance,
Johannes
definelicht
I went to the Alveo user guide, and it seems like the solution is the same.
There's a new "Getting Started" page:
https://www.xilinx.com/products/boards-and-kits/vcu1525-a.html#gettingStarted
Here there are three packages that must be installed, the OpenCL runtime (XRT), the shell, and the DSA.
My SDAccel seems to be building now.
definelicht
