rbriegel
How to set route directives in Vitis 2019.2?
Currently I use the V++ Linker Flag
"--vivado.prop run.impl_1.strategy=Performance_Explore"
how would I go about If I want to alternate a single directive for that strategy? In my case I want to set
" route_design -directive  MoreGlobalIterations "
Thanks in advance!
syedz
@rbriegel
Try "prop=run.impl_1.STEPS.ROUTE_DESIGN.ARGS.DIRECTIVE=MoreGlobalIterations"
Check page 170: https://www.xilinx.com/support/documentation/sw_manuals/xilinx2019_2/ug1393-vitis-application-acceleration.pdf#page=170
--Syed
syedz
@rbriegel
--Syed
rbriegel
Thanks, for the prompt reply, that seems to be it!
I have another question:
Is it possible to define multiple runs with different implementation strategies as well? Or would I have to do that manually?
cheers
hongh
For multiple runs exploring, you have to do it in Vivado project(generated in Vitis).
graces
To add, in the current Vitis release, please refer to the following for running multiple implementation strategies for timing closure:
https://www.xilinx.com/html_docs/xilinx2020_2/vitis_doc/buildingdevicebinary.html#wef1602451317007
If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs.
