spark1001
How to use OpenCL 1.2
The Document 'ug1393'  says  that the Vitis core development kit supports the OpenCL 1.2.
When I use the zcu102 Vitis Embedded base platform from here ,the result of  clGetDeviceInfo says the version of OpenCL is 1.0
char version [100];
err=clGetDeviceInfo(devices[i],CL_DEVICE_VERSION,sizeof(version),&version,NULL);
printf("version of this device is %s\n",version);
char D_version[20];
err=clGetDeviceInfo(devices[i],CL_DRIVER_VERSION,sizeof(D_version),&D_version,NULL);
printf("version of this driver is %s\n",D_version);
how to use OpenCL1.2?
kmorris
Thanks for confirming. As far as the version you are seeing, this was talked about in another post:
https://forums.xilinx.com/t5/Alveo-Accelerator-Cards/Which-version-of-OpenCL-the-alveo-card-support-does-it-support-1/td-p/1230001
so the version you are seeing would be accurate as only the host code would support the v1.2 API calls, but not the kernel.
Please don’t forget to reply, kudo, and accept as solution!
kmorris
Just to check, have you installed the appropriate libraries for OpenCL referenced here?
spark1001
I have already installed the libraries before I run my program.
kmorris
