How to use UART0 instead UART1 in sdsoc with linux ?
Hi all
Can i change SDSOC uart1 console to uart0?
or how to clone the UART1 and UART0 with full duplex data link?
Please guide steps solution?
My setup:
Hardware: Microzed Embedded Vision Kit.
Design tool: SDSOC 2016.2 with mzembv sdsoc platform.
Operating System: Linux.
Tags (4)
You will need to re-spin platform to do this. You would need enable this in the Vivado project in the PS config.
Then you would need to update the HW, and create the HDF. You can use this HDF to create the linux kernel.
Finally, you would need to re-create the platform
When you build linux image choose appropriate uart.
In petalinux config, you can choose from 'serial settings'.
Ravi
Thank you Stephenm
Is there a step-by-step guide to doing this?
Thank you Ravi
Is there any step-by-step guide to creat sdsoc platform?
Best regards
Masih
