mnsgs
Installation of program_flash
Prior to the introduction of Vitis, I used to install XSDK to gain access to program_flash used for flashing zynq/zynqmp targets through JTAG. Disc consumption was about 7GB, which appears an extreme overhead given that I need just the small CLI utility - I could however live with that.
Now, the Vitis web installer initially allows me to choose between Vivado and Vitis, but despite choosing Vitis, Vivado installation is forced - please refer below screenshot
and as a consequence I need to install ~90GB of data to gain access to program_flash tool - why am I not allowed to install Vitis without Vivado (as was the case for XSDK)?
It is obvious, that I am missing something here - what is the recommended means for program_flash installation? https://www.xilinx.com/html_docs/xilinx2019_2/vitis_doc/Chunk350813355.html#dxp1543754625265 describes:
"Xilinx Software Command-line Tool (XSCT) can be installed using the small self-extracting web install executable binary distribution file. The installer file bears the name Xilinx_vitis_<version>_Lin64.BIN, where <version> indicates the Vitis IDE version number."
But from where do I download this web installer allowing installation of just XSCT?
Martin
Tags (2)
mnsgs
No response from Xilinx? There must be a better way to get hold of just program_flash...
Tags (2)
