Is Sdx can generate IP used in Vivado
Hi all, I am trying to learn the hls video, but i see that the hls is deprecated in 2018.3, the replacement is xfopencv, now i want to know that is there a method for sdx to generate Ip core used in vivado just like vivado HLS,  you answer will be appreciated, thanks
Re: Is Sdx can generate IP used in Vivado
@fengwuxxx
Vivado HLS is not deprecating at all. You can create IP using Vivado HLS.
SDx is a word which is used for SDSoC and SDAccel together.
You can still use the HLS designs with SDx to create a complete system.
Further, the xfOpenCV library is a set of 50+ kernels, optimized for Xilinx FPGAs and SoCs, based on the OpenCV computer vision library. The kernels in the xfOpenCV library are optimized and supported in the Xilinx SDx Tool Suite.
/ 7\7     Meher Krishna Patel, PhD
\ \        Senior Product Application Engineer, Xilinx
\_\/\7   It is not so much that you are within the cosmos as that the cosmos is within you...
@fengwuxxx
