candycrush
Is it okay to make supported MIG IP to be RTL kernel using vitis?
I want to make supported MIG IP as RTL kernel using vitis, because I should use a kernel(module) that output read/write command which is MIG IP's input
But as far as I know, Vitis automatically did MIG's role for kernel.
So I think there is no problem making MIG IP as kernel but there is a operation problem of duplicate operation (one is MIG operation, other is Vitis automatic memory operation).
Is there any method to prevent duplicate operation?
Thank you!
stephenm
You would need to do this via the AXI PFM properties in your Vivado design using the sptags. This will then use the MIG
stephenm
candycrush
Thank you for reply!
Is there any document to refer to learn how to change AXI PFM properties for it?
Thank u!
stephenm
I discuss the PFM properties in the blog series here:
https://forums.xilinx.com/t5/Design-and-Debug-Techniques-Blog/Creating-an-Acceleration-Platform-for-Vitis-Part-One-Creating/ba-p/1138208
By default, it will be MIG. you just need to select the AXI PORT
candycrush
Oh I see it now, sorry.
And thank u a lot!
