BiscuitsColonel
LZ4 compatibility of Vitis data_compress library
I'm currently testing LZ4 acceleration with the Vitis data_compress library.
I was interested in it during that time, so I would like to ask a question.
How can I decompress a file compressed using Vitis's LZ4 compression library with a regular LZ4?
In my verification, the decompression process failed as follows:
---Check the test file
# cat test.txt
1, oranges
2, apples
3, bananas
4, strawberries
5, grapes
---Compression process
# ./xil_lz4 -cx compress.xclbin -c test.txt
Found Platform
Platform Name: Xilinx
Found Device=xilinx_u280_xdma_201920_3
INFO: Reading compress.xclbin
Loading: 'compress.xclbin'
E2E(MBps) :0.02
LZ4_CR :0.92
File Size(B) :47.000
File Name :test.txt
Output Location: test.txt.lz4
Compressed file size: 51
---Check the compressed file
# ls
compress.ltx link
compress.xclbin logs
compress.xclbin.info test.txt
compress.xclbin.link_summary test.txt.lz4
decompress.ltx v++_link_compress_guidance.json
decompress.xclbin v++_link_compress_guidance.pb
decompress.xclbin.info v++_link_decompress_guidance.json
decompress.xclbin.link_summary v++_link_decompress_guidance.pb
emconfig.json xil_lz4
ext_metadata.json xsa.xml
---Decompression processing with normal LZ4
# lz4 -d test.txt.lz4
Decoding file test.txt
test.txt already exists; do you wish to overwrite (y/N) ? y
Error 66 : Decompression error : ERROR_headerChecksum_invalid
---Decompression processing with Vitis LZ4
# ./xil_lz4 -dx decompress.xclbin -d test.txt.lz4
Found Platform
INFO: Reading decompress.xclbin
Loading: 'decompress.xclbin'
E2E(MBps) :0.03
File Size(B) :70.000
File Name :test.txt.lz4
Output Location: test.txt.lz4.orig
# cat test.txt.lz4.orig
1, oranges
2, apples
3, bananas
4, strawberries
5, grapes
Does this indicate that LZ4 in the Vitis data_compress library is incompatible with regular LZ4?
Or, it is possible to decompress with normal LZ4, but is the procedure wrong?
please tell me.
BiscuitsColonel
hatchuta
Hi @BiscuitsColonel ,
Can you please let me know which design you have tried for the test file ?
Meanwhile i will look into the issue and get back.
BiscuitsColonel
BiscuitsColonel
