kennetho
Multi DDR bank support
I have an sdaccel project with HLS kernel. I'm attempting to make use of the new multi ddr bank functionality to increase memory bandwidth. I get a link error:
INFO: [XOCC 60-629] Linking for hardware target
INFO: [XOCC 60-423] Target device: xilinx:adm-pcie-ku3:2ddr:2.1
INFO: [XOCC 60-242] Creating kernel: 'smithwaterman'
INFO: [XOCC 60-694] Validating user connections (map_connect)...
INFO: [XOCC 60-690] User connection 'kernel|k1|M_AXI_GMEM0' is valid
INFO: [XOCC 60-690] User connection 'core|OCL_REGION_0|M00_AXI' is valid
INFO: [XOCC 60-690] User connection 'kernel|k1|M_AXI_GMEM1' is valid
INFO: [XOCC 60-690] User connection 'core|OCL_REGION_0|M01_AXI' is valid
INFO: [XOCC 60-690] User connection 'kernel|k1|M_AXI_GMEM2' is valid
INFO: [XOCC 60-251] Hardware accelerator integration...
ERROR: [XOCC 60-704] Integration error, problem with OCL region: Found connection from kernel 'k1/M_AXI_GMEM1' to multiple master interfaces
ERROR: [XOCC 60-626] Kernel link failed to complete
ERROR: [XOCC 60-703] Failed to finish linking
Relevant code snippets:
From the kernel:
void smithwaterman(ap_uint<NUM_ELEM_BITS>  *g_query, ap_uint<NUM_ELEM_BITS> *g_database, ap_int<512> *directionMatrix)
  #pragma HLS INTERFACE m_axi port=g_query offset=slave bundle=gmem0
  #pragma HLS INTERFACE m_axi port=g_database offset=slave bundle=gmem1
  #pragma HLS INTERFACE m_axi port=directionMatrix offset=slave bundle=gmem2
  #pragma HLS INTERFACE s_axilite port=g_query bundle=control
  #pragma HLS INTERFACE s_axilite port=g_database bundle=control
  #pragma HLS INTERFACE s_axilite port=directionMatrix bundle=control
  #pragma HLS INTERFACE s_axilite port=return bundle=control
  From the host;
    cl_mem_ext_ptr_t input_a_ext;
    cl_mem_ext_ptr_t input_b_ext;
    cl_mem_ext_ptr_t output_ext;
    input_a_ext.flags = XCL_MEM_DDR_BANK0;
    input_a_ext.obj =  query_param;
    input_a_ext.param = 0;
    input_b_ext.flags = XCL_MEM_DDR_BANK1;
    input_b_ext.obj =  database_param;
    input_b_ext.param = 0;
    output_ext.flags = XCL_MEM_DDR_BANK0;
    output_ext.obj =  results2;
    output_ext.param = 0;
  input_a = clCreateBuffer(context,  CL_MEM_READ_ONLY | CL_MEM_EXT_PTR_XILINX,  sizeof(unsigned int) * N/16, NULL, NULL);
  input_b = clCreateBuffer(context,  CL_MEM_READ_ONLY | CL_MEM_EXT_PTR_XILINX,  sizeof(unsigned int) * (M + 2*(N - 1))/16, NULL, NULL);
  output = clCreateBuffer(context, CL_MEM_WRITE_ONLY | CL_MEM_EXT_PTR_XILINX, sizeof(char)* 256*(N+M-1), NULL, NULL);
From the tcl:
map_connect -opencl_binary [get_opencl_binary smithwaterman] -src_type "kernel" -src_name "k1" -src_port "M_AXI_GMEM0" -dst_type "core" -dst_name "OCL_REGION_0" -dst_port "M00_AXI"
map_connect -opencl_binary [get_opencl_binary smithwaterman] -src_type "kernel" -src_name "k1" -src_port "M_AXI_GMEM1"  -dst_type "core" -dst_name "OCL_REGION_0" -dst_port "M01_AXI"
map_connect -opencl_binary [get_opencl_binary smithwaterman] -src_type "kernel" -src_name "k1" -src_port "M_AXI_GMEM2" -dst_type "core" -dst_name "OCL_REGION_0" -dst_port "M00_AXI"
Any tips?
kennetho
Working in 2016.1 HEAD
ywu
Ken,
What you have looks correct to me. Can you share your design so that I can take a look? Which version of the tool are you using? If you are using 2015.4, I will need to provide you a patch for using C/C++ kernels on 2DDR DSA.
Cheers,
Jim
kennetho
Hi Jim,
Code is attached. I'm building this with 2016.1 daily branch as the underlying HLS in 2015.4 has a bug exposed by this code.
Ken
ywu
Hi Ken,
Since this design can compile in 2015.4, so there is nothing wrong as far as usage is concerned. Please file a CR against 2016.1 on this.
What issue is exposed by this code in 2015.4? Is there a CR? We did find an issue and a patch is available.
@kennetho wrote:
Hi Jim,
Ken
Cheers,
Jim
kennetho
Hi Jim,
I'll file a CR against 2016.1. In 2015.4, we find that HLS increasingly allocates memory until it is killed by the OS. Our build machine has 64GB of ram. I had throught that we had a CR on this, but I am mistaken. Filing now.
Best Regards,
Ken
ywu
Hi Ken,
Since 2016.1 is already working for this design as far as HLS is concerned, you don't need to file a CR against 2015.4 on the memory issue.
@kennetho wrote:
Hi Jim,
Best Regards,
Ken
Cheers,
Jim
kennetho
Hi Jim,
Thanks. I've filed a CR (941250) on the 2016.1 branch.
Best Regards,
Ken
ywu
Hi Ken,
If you need to try this soon, I will send you a workaround. Otherwise, just wait for the issue to be fixed in 2016.1 branch.
@kennetho wrote:
Hi Jim,
Best Regards,
Ken
Cheers,
Jim
kennetho
Hi Jim,
A workaround would be greatly appreciated. We're trying to wrap up this project and this is likely our final build.
Best Regards,
Ken
ywu
Hi Ken,
I will send you the workaround via email.
@kennetho wrote:
Hi Jim,
Best Regards,
Ken
Cheers,
Jim
kennetho
